neste caso é mais uma decisão do colega compar a dele na sportzone, mas claro aproveito esclareço a duvida dele e as minhas( pois pode haver um bom negocio)
o meu unico requesito, é compar em loja fisica
berg fuego 8.9 2013 899€
Aluminio 6061 TT/DT
Forqueta carbono COLUMBUS
FSA 1 1/8
Shimano TIAGRA FD-4600 / Tiagra RD4600
mudanças Shimano 105
Rodas Mavic Aksium Race
Pneus: SCHWALBE LUGANO PP 700x23C
SHIMANO TIAGRA FC-4650, 50X34
berg fuego 8.6 TT 2013 699 ou 799€ (ja nao me lembro)
Shimano Sora
Rodas Shimano A500
fuji sportif 2 799€
SIZES XS (46cm), S (49cm), S/M (52cm), M (54cm), M/L (56cm), L (58cm), XL (61cm)
COLOR(S) Matte Black
MAIN FRAME A2-SL compact double-butted alloy w/ hydroformed top tube & down tube, integrated head tube, double water bottle mounts
REAR TRIANGLE A2-SL alloy tapered seatstays/chainstays w/ rack mount, forged-road dropout w/ 1 eyelet and replaceable derailleur hanger
FORK FC-770 carbon integrated w/ 1 1/8" alloy steerer
CRANKSET Fuji forged alloy, 50/34T
BOTTOM BRACKET FSA Sealed cartridge bearing
PEDALS Aero Road platform w/ clips and straps
FRONT DERAILLEUR Shimano Sora, band-type 34.9mm
REAR DERAILLEUR Shimano Tiagra
SHIFTERS Shimano Sora shifter/brake, Flight Deck-compatible, 18-speed
CASSETTE Shimano HG50 , 11-32T, 9-speed
CHAIN KMC X9, 9-speed
WHEELSET Vera Corsa double-wall aero alloy clincher, 20/24H alloy road rims, bladed spokes
TIRES Vera Helios, 60 tpi, 700c x 25mm, wire bead
BRAKE SET Alloy dual pivot, 47mm-57mm reach
BRAKE LEVERS Shimano Sora STI
HEADSET FSA Orbit CE 1 1/8" integrated w/ alloy top cover
HANDLEBAR Oval 301 6061 alloy, 31.8mm
STEM Oval 313 3D-forged 6061 alloy, 31.8mm, +/- 7 degrees
TAPE/GRIP Oval 300 suede-padded tape
SADDLE Oval R300
SEAT POST Oval 300 double-bolt, alloy 27.2mm x 350mm
WEIGHT, LB./KG. 22.22 lbs / 10.1 kg
GT R series 3 2013 928€
Frame: GTR alloy frame with smooth welds, hydroformed (TT,DT), full eyelets
Fork: GTR Carbon 1 1/8" threadless alum steeler
Chain: KMC X10
Crank: FSA Vero Compact 50/34
Bottom Bracket: Sealed Cartridge
Pedals: New Low Profile Nylon w/ Toe Clips
Front Derailleur: Shimano Tiagra
Rear Derailleur: Shimano Tiagra 10spd
Shifters: Shimano Tiagra STI 10 spd
Cog Set: Shimano Tiagra 10spd 12-28
Rims: Jalco DRX-4000 Aero type alloy rims, CNC sides
Tires: Vittoria Zaffiro 700 x 25c
Hubs: Formula sealed
Rear Hub: Formula sealed casette
Spokes: 15g stainless steel
Nipples: Brass CP
Brake: Tektro Dual Pivot Light, R420 alloy cartridge with swiss stop pads
Brake Levers: Shimano Tiagra 10 spd STI
Handlebar: New GT Shallow drop 6061 alloy
Stem: New GT Design 3D forged 6061, 4 bolt face plate
Grips: Black Cork
Headset: Integrated TH sealed bearing
Saddle: New GT Bio-Morphic RACE duel density base
Seat Post: Two bolt aluminun
Seat Clamp: Alloy with Nickel finish
scott speedsper 2012 850€
Frame: SCOTT Speedster Double Butted 6061 Alloy, Aero shape
Fork: Carbon/Alloy, 1 1/8 "
Group set: Shimano Tiagra
Brakes: SCOTT Pro
Parts: Syncros Road Series
Wheels: Syncros Race 28 Aero Profile
**escolhi imagens iguas as bicicletas que vi
